Lucantropo ha scritto:e cmq anche aprendo il cofano la turbina è messa la sotto non si vede benissimo e non penso che ci sia scritto sopra marca e modello..
P ma proverò a sbirciare!
Credo che il turbo della saab come le nostre non sia il Mitsubishi TD04.
E' scritto solo Garrett (questo però e di una Saab 9000)
Leggi qui:
TD04 Turbocharger Upgrade, Upto 70 BHP Increase, £1199. Part Number: CEN001
Over the years we have often been asked for "Hybrid" turbos for SAAB's. We have always been cautious as Hybrid turbos (ie. One-off specials) are often unreliable. Concious of the need to satisfy our tuning instincts and customers needs, we have come up with the ideal solution.
We have taken the 9000 Aero proven Mitsubishi TD04 Turbocharger, and developed a fitting kit around it to offer a totally reliable installation for the SAAB 900 2.0 Turbo Engine.
Kit Features
A new Mitsubishi TD04 Turbo.
Gas flowed exhaust manifold, matched to flow perfectly into the larger inlet turbine port of the TD04.
Our own custom hardlines for Water and Oil, along with the required fittings.
Exclusive High-Pressure silicone hose to cope with the increased compressor capability.
Wastegate Actuator and Mounting bracket.
The TD04 Flows 20% more air than the standard turbo, and is a proven turbo design as fitted standard on the 9000 2.3 Aero model. The larger TD04 pumps more air above 3500 RPM than the standard turbocharger, allowing the engine to produce much more power at higher revs.
At 4000 RPM where a standard Turbo is running out of pressure, the increased compressor capacity of the TD04 keeps the Turbo boosting, providing a huge surge of power up to the rev limiter at 6100 RPM.Discounts available on Intercooler and Engine Management upgrades when purchased with the TD04 Upgrade, allows for power increases of upto 70 BHP.
Trionic ECM Upgrade, £295 (Normally £360).
Hi-Flow Intercooler, £395 (Normally £495).
Fitting
The kit takes approximately 4.5 hours to fit. We can install the TD04 kit at our workshops for a fixed price of £200.
