tipo di olio
leo79
tipo di olio
Salve a tutti, volevo sapere che tipo di olio mettete sul motore della saab 9.3 ss motore 2.2 tdi. grazie
- Gho57
Re: tipo di olio
da libretto 0w40 mobil1 ma ora è stato sostituito in quasi tutte le officine autorizzate da un generico 5w30GM.
mc59
Re: tipo di olio
Ho trovato questa lettera del servizio U.S.A. e parla di mobil 1 e cambi da un minimo di 8.000 migli 12.000 km a un massino di 15.000 miglia 22.000 Km
Date: 12/2/02
To: All Saab Dealers
Saab Service Manager
Saab Parts Manager
Code: 100/200
Reference: REVISED - Recommended oil grades for 2003 Model Saabs including 9-3 Sport Sedan Service Intervals/Requirements
All 2003 Saab models will come with an underhood label indicating "Recommended oils/Use Saab Genuine Oil/Mobil 1". It is important that the different requirements for each model is understood.
9-3 Sport Sedan Service Intervals/Requirements: Requires Full Synthetic oil which meets GM-LL-A-025 specification
The Saab 9-3 Sport Sedan enters a new level of maintenance intervals and requirements. Service intervals fall under main categories: Intermediate and Main Service interval. A message on SID indicates to the owner when either service is required.
MAIN SERVICE interval is based entirely on mileage driven: 30,000; 60,000 and 90,000 miles.
INTERMEDIATE SERVICE is set by an algorithm that determines when service is required. Miles driven, crankshaft revolutions, number of starts/cold starts, ambient temperatures, speed and engine temperature are among the measurements used to compute the interval with the TIME FOR SERVICE message being set between 8,000 and a maximum of 15,000 miles. If the mileage interval is not met, the message will be set at 2 years.
NOTE: The actual oil condition is NOT measured, only the above calculations performed.
It is important to note that this computation is based on the use of fully-synthetic oil which meets GM-LL-A-025 specification. This is a specification that is currently not commonly found in the US. The only oils that are readily available that meet this specification are Mobile 0W40 SuperSyn and Saab 0W30 Turbo Long-Life Fully Synthetic oil.
Saab Fully Synthetic Turbo oil is available under the following part numbers:
12 799 131 = 4 liter container
12 799 130 = 1 liter container
Sincerely,
Rich Miller
Manager,
Technical Services Quality
Abe Buchbinder
Director,
Product Quality and Service
Date: 12/2/02
Saab Parts Manager
Code: 100/200
Sincerely,
Rich Miller
Manager,
Abe Buchbinder
Director,
